96 Honda civic ran then washed engine then problem started! Any ideas?
- mhageman426
8 years 6 months ago #19989
by mhageman426
96 Honda civic ran then washed engine then problem started! Any ideas? was created by mhageman426
Car got me from point a to b until washed engine then wouldn't start. Distributor cap and rotor fried so replaced. Now it starts ,idles then dies. If I push on gas to keep it running it (misfires) big puff of smoke comes out by intake filter then dies. Has to sit 15-20 minutes before it will run and not just crank?
8 years 6 months ago #19995
Replied by Tyler on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
First thing that occurs to me is that you still have water in the spark plug tubes. If you haven't already, pull the wires and have a look. Dry as needed.
Are you positive you had the distributor correctly timed? I doubt you could install it 180 degrees out, but the timing adjustment still allows for enough movement to cause issues.
- randall.sick
8 years 6 months ago #20011
by randall.sick
My rides, 1998 Chevy Tahoe 5.7l
1999 Chevy S10 2.2l
Replied by randall.sick on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
I agree with Tyler, it sounds like you have the distributor set a tooth off. When it sputters is it throwing a code? I would make sure to set #1 to TDC and re-set your distributor.
1999 Chevy S10 2.2l
- Pinto
- Thank you received: 2
8 years 6 months ago #20059
by Pinto
Replied by Pinto on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
Did you replace the whole distributor or just the cap and rotor? if not then the igniter and pick_up coils below the cap are shorted probably. I think Honda distributor can be installed one way only..
- mhageman426
8 years 6 months ago #20147
by mhageman426
Replied by mhageman426 on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
You are correct Tyler! After I posted my question thought about it and later that day it started but still acting like it was bogging down like being suffocated. I checked intake filter and then I thought that the exhaust was coming in the car so low and behold the foam bumper mold had broke lose and partly covering the pipe. Removed it and it ran just fine , Until 2 days ago when I guy hit me so hard his front tire broke off his truck!! Totaled out my car!! Thanks for the help everyone!!
8 years 6 months ago #20162
Replied by Noah on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
Oh man, that's a rough break!
- slackware
8 years 3 weeks ago #23965
by slackware
Replied by slackware on topic 96 Honda civic ran then washed engine then problem started! Any ideas?
So what is the code for pickup truck in intake manifold?
