04 mercury grandmarquis 4.6
  • the mechanic.88
  • the mechanic.88's Avatar Topic Author
8 years 6 months ago #20089 by the mechanic.88
04 mercury grandmarquis 4.6 was created by the mechanic.88
I need help this car stalls randomly when drivin or turning on orners and starts right back up checkd battery terminals fuel pressu only with scanner it looks good checked maf sensor good too the only thing that i no is that they had this car fo 8 months parckedhopefully you guys can help me thsnks....
8 years 6 months ago #20095 by BroncoMcbane
Replied by BroncoMcbane on topic Re:RE: 04 mercury grandmarquis 4.6
the mechanic.88 wrote: I need help this car stalls randomly when drivin or turning on orners and starts right back up checkd battery terminals fuel pressu only with scanner it looks good checked maf sensor good too the only thing that i no is that they had this car fo 8 months parckedhopefully you guys can help me thsnks....
It stalls only when turning or driving around corners?
Have you checked the positive battery cable itself and the motor mounts? The terminals can be good but the cable may be stretched. Additionally bad motor mounts may pull at the cable when you accelerate the engine into or out of the turn.
Another issue may be fuel sock in the tank may shift when you go around turn.
Also, check the wiring harness going from the PCM to the sensors. A frayed wire or loose pins or loose connection or corroded ground wire to the body.
The Thermoquad Cowboy
