hyundai sonata 2015 steering
  • repsol12
  • repsol12's Avatar Topic Author
8 years 6 months ago #20123 by repsol12
hyundai sonata 2015 steering was created by repsol12
Hi ,got this sonata that came with no power steering ,the steering and stability light are on. Car has been to the dealer prior me and they quote a column assembly at 5 000.00$ . No warranty since the mileage at 200k , the codes are C1260, steering angle sensor and C1688, issues with motor driven power steering module MDPS. Found a used column assembly ,everything included ,motor, mdps . Installed the unit ,reprogram the vin try to reset the angle sensor to end up with the same codes, verus and autel were used to reset . The codes are set in the ESP electronic stability program module (abs unit) ,impossible to erase . no dtc in th MDPS . Steering angle data in the mdps stay at 0 and in th ESP at 3261 rotation degrees ,default value! There is a youtube : Hyundai Kia steering angle reset problem , by Phill lambert , aligment instructor , but no clues to reset. Do i need the factory scanner GDS ?? Thank Dan !!!
8 years 2 months ago #22780 by kdauto
Replied by kdauto on topic hyundai sonata 2015 steering
I believe we may be working on the exact same vehicle. Is this P.B.? It is now at 220 000 km, still the same. I worked on it 6 months ago.
Trying a few morre things, GDS was tried on this one and steering angle sensor relearn didn't take.
  • repsol12
8 years 2 months ago #22950 by repsol12
Replied by repsol12 on topic hyundai sonata 2015 steering
This one is gone, a new column fix it . I still dont understand why the used unit never worked and yes kd it's the same car !!!!!
8 years 2 months ago #22956 by kdauto
So the guy FINALLY went for a new column? In February I told him I needed the original column and parts for testing and programming and he didn't come back. Last week He came back and I went through the entire CAN bus, fixed a splice pack RH dash behind glove box (removed 1/2 of dash), disconnected some crappy surveillance cameras hooked up to OBD2 port wires and FINALLY got the steering angle sensor relearn to function. At THAT point I got a code for shorted motor. It appears both original and salvage column parts had the same defect. He was upset at paying for a non-fix but he didn't want to pay 3000$ for a new column.
Did he really buy a new column? If so, I will tell him to keep going elsewhere next time. I'm pissed I didn't make $$$ on the column job.
Is this Daniel from Ste-Sabine?
