P0135
- autojoe
- Thank you received: 7
8 years 6 months ago #20236
by autojoe
P0135 was created by autojoe
Here's my question.... With a 02 heater code is the pcm monitoring the signal line for time to activity test or is it directly measuring the amperage draw of the heater circuit when it commands it on pwm? I was thinking before pwm it would monitor signal line and after pwm it monitors amperage directly on the circuit. All the data pids on scan tool for amperage. Is this correct? I am talking about gm vehicles.
- Ben
- Thank you received: 215
8 years 6 months ago #20239
by Ben
Replied by Ben on topic Re:P0135
May vary but the latest couple I have done it monitored the amperage on the ground side switched heater circuit
- Ben
8 years 6 months ago #20240
by Ben
After re reading your question I see your asking of pre pwm system as well and on that old system I'm not sure it monitored anything other than complete circuit of heater someone may have a better answer there though.
- autojoe
8 years 6 months ago #20281
by autojoe
Replied by autojoe on topic Re:P0135
One of Pauls videos looking at signal time to response test. P0135 enabling criteria for code to set is above I think 3.25 amps and below 1/4 Amp.
