2005 Mazda 6 with JDM motor what start.
- kirkjenn
thanks,
kirk
If this is a two wire sensor, then it's a Variable Reluctance sensor, and neither one will have power at any time. Neither will the crank sensor. These are sensors that generate their own voltage, and don't use dedicated power feeds. Check out this post from another Mazda engine swap thread for an example of what the signals are supposed to look like:
www.scannerdanner.com/forum/post-your-re...m.html?start=34#4750
Does this engine start at all? Or does it lose spark intermittently?
- kirkjenn
- kirkjenn
- kirkjenn
kirkjenn wrote: I'm using the same PCM that was with the car. 2005 2.3 liter engine. Bought the JDM motor from orlando and this is also a 2.3 liter engine.
Sweet, that makes testing a ton easier.
I've check the timing a dozen times and used my timing tools to make sure the timing is correct with making sure I'm at TDC and the cams are also aligned as well. Still no turn over.
When checking the timing, you're using the camshaft alignment plate, the crankshaft locking pin, AND the M6 bolt through the crankshaft pulley into the timing cover? I really don't mean to nitpick or second guess you.
It sparks, but its intermittently, not like it should. The engine doesn't start at all.
Gotcha. I totally understand why you're questioning the cam signal at this point. Do you have access to a two channel scope? That'd answer a lot of questions about what the PCM is seeing on the cam and crank signals. If not, no worries, we can get by without it.
- kirkjenn
Yes, I did the timing exactly as you stated. Cam tool/TDC bolt/ and the M6 bolt. Timing I've check myself a dozen times and its perfect thats why I'm so confused on why its not firing....Please reply and let me know what I"m doing wrong. This has been a lengthy project for my son and I. After work and after school for him... Lots of hours under the hood:). Any help I would really appreciate it.
- kirkjenn
please help.
kirk
- Sacred1sxy
