2003 Mitsubishi Diamante Rough Idle
- Spetz
8 years 6 months ago #20335
by Spetz
2003 Mitsubishi Diamante Rough Idle was created by Spetz
Hi everyone,
I have a 2003 Mitsubishi Diamante with a poor idle.
It is non-rythmic and at times idles smooth, at times really bad and most of the time just bad.
I have checked all the sensors, compression test, injectors replaced, idle RPM is steady, vacuum test, air leak test done etc
Took it to 2 mechanics who cannot diagnose it.
Changed plugs, leads, distributor, distributor cap, rotor, all filters etc.
PVC system is OK.
O2 sensor will be replaced soon but just hoping someone can suggest something?
It seems to be a common issue with these cars not idling well but no one knows the answer
PVC system is OK.
- cheryl hartkorn
- Thank you received: 130
8 years 6 months ago #20336
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2003 Mitsubishi Diamante Rough Idle
sticking open egr valve?
- Spetz
8 years 6 months ago #20341
by Spetz
Replied by Spetz on topic 2003 Mitsubishi Diamante Rough Idle
I put a blanking plate on the EGR port and it made no difference.
Also when the hose is pulled off of the EGR solenoid and a vacuum pump the idle gets much worse so the valve seems operational
- kekekekevin95831
8 years 6 months ago #20343
by kekekekevin95831
Replied by kekekekevin95831 on topic 2003 Mitsubishi Diamante Rough Idle
I just done diagnosing a 03 Mit Lancer with randon rough idle. In my case it was a faulty MAF that’ll drop out its signal intermittently. So check the MAF and Iac too. Hope this helps
