2002 ram 1500 4.7L P1495
- Matts Auto
- Thank you received: 28
8 years 6 months ago #20357
by Matts Auto
2002 ram 1500 4.7L P1495 was created by Matts Auto
Tested all 3 wires to LDP & orange wire shows nothing. Did resistance test from pcm connector to LDP connector on orange wire & checks good with load. PCM ? what's your thoughts? White wire with green stripe is grounded with LDP turned on with scan tool & white / blue stripe has battery voltage.
- Matts Auto
8 years 6 months ago #20382
by Matts Auto
Replied by Matts Auto on topic 2002 ram 1500 4.7L P1495
*FIXED* So i had a brain malfunction yesterday testing this circuit. I misread schematic. Was thinking orange wire to LDP was control wire & it was white / green stripe. I discovered someone had replaced clutch master cylinder & pinched white / green wire (control) between firewall & master (grounding wire). Momma said there would be days like this!!!
- Matts Auto
8 years 6 months ago #20383
by Matts Auto
By the way anyone interested control wire is suppose to pulse signal not steady ground.
- bruce.oliver
- Thank you received: 88
8 years 6 months ago #20417
by bruce.oliver
Replied by bruce.oliver on topic 2002 ram 1500 4.7L P1495
Good fix. Glad you kept at it before selling a PCM
- Matts Auto
8 years 6 months ago #20418
by Matts Auto
Me too. Thank you. Made me feel foolish when I misread diagram & tested wrong but fortunately i double checked myself.
