Po332
- Dtnel
- Thank you received: 67
8 years 5 months ago #20521
by Dtnel
Po332 was created by Dtnel
04 Chevy Tahoe 4.8 119k miles. Driving along the other day and the check engine light comes on. Pulled codes and found the po332. Was looking at it and noticed I saw some misfires from some cylinders that come and go on the live data but more often they're not showing misfire that showing it.
After a little thinking I realized I forgot to replace my plugs and wires at 100k. I'm sure this isn't going to contribute to this code unless it's a known issue of not doing the 100k plugs and wire change out.
Where can I find the specs for this year, make, model so when I test I know what I'm looking for with the knock sensors and wiring. I'll find a couple threads or a how to somewhere hopefully and go from there.
Any and all advice appreciated.
To add further insult to injury this does have a exhaust manifold gasket leak at drivers rear where the bolt broke over a year ago and just haven't taken the time to do that, it's a broken bolt so I'm always scratching my head.
Wondering if I should get a broken bolt remover bracket kit from the tool truck or not as I plan on keeping this SUV alot longer as I'm original owner and I'm sure the one bolt isn't the only one that be broke by the time I'm done no matter how well I soak them down with pb blaster after turning the vehicle off.
- Matts Auto
- Thank you received: 28
8 years 5 months ago #20535
by Matts Auto
Replied by Matts Auto on topic Po332
From my experience p0332 usually requires replacing knock sensors & harness. Harness is usually brittle n looses continuity. There is a tsb on that which says to make a dam around each sensor with high temp silicone to keep water intrusion out.
- Dtnel
8 years 5 months ago #20540
by Dtnel
Replied by Dtnel on topic Po332
Interesting as I had the scan tool up and checked for TSB's related and it never showed any TSBs related. I'm not doubting but with how I've been learning I always look for related TSBs first anymore as something may address it this saving a bunch of time.
I'll let the vehicle cool down after I take the daughter to acgoom tomorrow and see what I can find.
Wonder what the specs are regarding checking the sensors and what I should be looking for resistance and likewise.
- Matts Auto
8 years 5 months ago #20544
by Matts Auto
Resistance should be 93-107k on connector at left side of intake manifold.
- Matts Auto
8 years 5 months ago #20545
by Matts Auto
Tsb 02-06-04-023A
The following user(s) said Thank You: Dtnel
