2001 impala purge valve
- Ninjaxchicken
- Thank you received: 7
8 years 5 months ago #21008
by Ninjaxchicken
2001 impala purge valve was created by Ninjaxchicken
purge valve is pulsating at idle rapidly open and closed... if i unplug the connector and take a test light from battery negative to plug hot wire it steady glows with 12 volts... if i take the test light from battery postivie and touch the computer controlled ground wire the test light pulses as the purge solenoid would be doing... is this normal?
- gav09
- Thank you received: 24
8 years 5 months ago #21009
by gav09
Replied by gav09 on topic 2001 impala purge valve
Its normal. You can look at purge command percentage on a scan tool and see the ecm commanding purge.
- Ninjaxchicken
8 years 5 months ago #21010
by Ninjaxchicken
Replied by Ninjaxchicken on topic 2001 impala purge valve
Thanks for the response.. the only scan tool i have is a blue driver scan tool so it doesnt allot me to view things like that... some live info but nothing like that
- bruce.oliver
- Thank you received: 88
8 years 5 months ago #21024
by bruce.oliver
Replied by bruce.oliver on topic 2001 impala purge valve
Perfectly normal monde. I've seen lots of cars pulse the purge solenoid at idle
The following user(s) said Thank You: Noah, Monde
- autojoe
8 years 5 months ago #21027
by autojoe
Replied by autojoe on topic 2001 impala purge valve
Why are you checking? Rough idle? Mil on? If so what code is stored in pcm?
