My Colorado Fog lights work with the scan tool bi-direction feature, but not with switch. I suspect a bad switch. I already did the diagnosis in checking the ground to ground voltage drop, and it's good. My question is when looking at the data pids and grounding the signal wire to enable the fog lights I see that it changes from not active to active, but the fog lights relay is not turning on. Any help is much appreciated. Thank you!!!
My understanding is when you do bi-directional commands you're skipping or bypassing the inputs to the BCM, to control the fog lamp relay. Are these BCM inputs responding correctly?
Headlamp On Switch
Headlamp Off Switch
Park Lamp Switch
Park Lamps Signal
Last edit: 1 year 8 months ago by ferris48. Reason: formatting
