07 impala with speedometer not working.
  • mariod987
  • mariod987's Avatar Topic Author
8 years 5 months ago #21102 by mariod987
07 impala with speedometer not working. was created by mariod987
hello, i'm working on an 07 chevy impala with a 3.5 engine. The problem im having is that the speedometer is not working because the ecm, bcm, are not seeing the vss signal. I have already fixed the wiring to the vss and also installed a new speed sensor. The tcm does see the signal as it shows vehicle speed and the transmission is shifting. On the cluster the abs and trac light are on but this car does not come equipped with abs module. I ohmed out the can lines and they read 60ohm. My question is what could be keeping the ecm and bcm from seeing the signal and what else can i check. Thank you.
8 years 5 months ago #21109 by Ben
Replied by Ben on topic 07 impala with speedometer not working.
These clusters have problems with the motors going bad are you sure your missing the speed signal to it? Have you performed a self test on the cluster to verify the speedometer works? Do you have a diagram of the vss? if not someone can post 1. Also lastly what did you repair in the wiring?
  • mariod987
8 years 5 months ago #21114 by mariod987
Replied by mariod987 on topic 07 impala with speedometer not working.
the wires going to the vss were broken in two spots, and yes i performed a gauge sweep on the cluster and all the gauges moved.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 5 months ago #21117 by cheryl hartkorn
Replied by cheryl hartkorn on topic 07 impala with speedometer not working.
any codes in an all dtc scan? do you have the description and opertion of which module the speed sensor goes through first
  • mariod987
8 years 5 months ago #21120 by mariod987
no codes in any of the modules, and the vss signal goes to the tcm, from there it gets send over the can lines to the ecu and bcm. after reading the operation on mitchell, it says that it will defalt to 0 mph if the bcm does not see the vss signal.
