P01391 Fault Code Jeep 4.7
  • Dhuffman
  • Dhuffman's Avatar Topic Author
8 years 4 months ago #21244 by Dhuffman
P01391 Fault Code Jeep 4.7 was created by Dhuffman
2000 Jeep Grand Cherokee 4.7 has a P01391 (intermitant cam / crank sensors) fault code. Jeep runs great, never stalls and always starts. Cam sensor was replaced (not mopar) and same problem. I have an Autel MS906BT scanner and just recently purchased the MP408 (4 channel scope) for it.
When I did a trace on the cam & crank sensors and compared to a 'known good' trace for the same 4.7 engine, they are identical. I cleared the PCM memory and then I made several drive tests (short and long) after clearing the code each time. If I drive 5, 20 or 40 miles the P01391 code never sets. If I shut the Jeep off, the next time I drive it the fault is not set until I drive a couple miles and then its back.
My next step is to connect leads to the cam / crank circuits, run a long USB lead into the Jeep to connect to the Autel and try to record the moment the fault code sets.
Just wondering if anyone has seen a similar problem. The road tests were done on days when the temperature was 60 degrees and others when it was 90 degrees. I even tried to recreate it in the garage standing still when the engine was so hot the electric fan kicked in to keep it cool.
8 years 4 months ago #21296 by Chad
Replied by Chad on topic P01391 Fault Code Jeep 4.7
Dhuffman wrote: My next step is to connect leads to the cam / crank circuits, run a long USB lead into the Jeep to connect to the Autel and try to record the moment the fault code sets.
I think you have the right Idea. Try wiggle-testing the wiring harness. The SET CONDITION for this code is when the failure counter reaches 20 for 2 consecutive trips. That means on the second trip when the code sets and the light comes on, the failure has already happened 20 times during that trip.
8 years 4 months ago #21301 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic P01391 Fault Code Jeep 4.7
It will be hard to find s glitch on the signal wire so I would look for an issue on the power and ground first. Check the power by back pinning at the sensor, same for the ground, you can use a low wattage test light to load both looking for glitches on the scope when you wiggle test. If you suspect the ground try a jumper wire to ground
Time to create page: 0.258 seconds
