2002 Dodge Dakota 4.7L engine start/stall [FIXED]
  • rdhays99
  • rdhays99's Avatar Topic Author
10 years 4 weeks ago - 9 years 10 months ago #2399 by rdhays99
I am having an issue with a 2002 Dodge Dakota 4.7L. The truck will start some of the time but upon a snap throttle test it stalls and will not start again for quite a while. I have checked cam sensor, crank sensor square waves, they are both there but can't fine any diagrams on correct correlation of the two. Also, the truck has coil and injector control. Injector and coils all have power when PCM has RPM signal. Any help would be greatly appreciated.
Last edit: 9 years 10 months ago by Noah.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
10 years 4 weeks ago #2403 by ScannerDanner
Replied by ScannerDanner on topic 2002 Dodge Dakota 4.7L engine start/stall
What is fuel psi when it won't start? Also what is the ECT showing? Any fault codes?
Don't be a parts changer!
  • rdhays99
10 years 4 weeks ago - 10 years 4 weeks ago #2413 by rdhays99
Replied by rdhays99 on topic 2002 Dodge Dakota 4.7L engine start/stall
Fuel PSI is around 42 PSI, i am not sure of ECT reading right this moment. I will have to recheck it this morning. Also, when the engine stalls, I loose scan data at that moment. The customer purchased a reman PCM that came preprogrammed. Conditions are the same with the old and replacement PCM.
Last edit: 10 years 4 weeks ago by rdhays99.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
10 years 4 weeks ago #2426 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2002 Dodge Dakota 4.7L engine start/stall
you lose scan data when it stalls? next time it does that check the 5 volt reference. might have a sensor pulling down the voltage.
  • rdhays99
10 years 3 weeks ago #2818 by rdhays99
Sorry for the delay in response. I looked at this truck again yesterday and found 45 PSI fuel pressure, ECT temp of 85 F. When the stall occurs there is no loss of 5v ref.
  • cheryl hartkorn
10 years 3 weeks ago #2821 by cheryl hartkorn
we are losing something, check for spark when it happens again and injector pulse
10 years 3 weeks ago #2839 by The Auto Tech
Replied by The Auto Tech on topic 2002 Dodge Dakota 4.7L engine start/stall
Are you losing all communication to the ecm when it stalls?
  • rdhays99
10 years 3 weeks ago #2842 by rdhays99
I am losing momentary scan data at the time of engine stall. then it comes right back but wen you try to start the truck it has data until the stall and then data is lost for that moment.
  • Chriscoy
  • Chriscoy's Avatar
  • Heavy duty truck technician / foreman/ parts guy/
10 years 3 weeks ago #2853 by Chriscoy
Replied by Chriscoy on topic 2002 Dodge Dakota 4.7L engine start/stall
I've run into this same symptom on a 2000 Durango with the 4.7 and the fix for me was a new TPS. I tore my hair out for a while trying to figure out what the problem was. It was running fine and out of nowhere it would stall. No rhyme or reason to it.
Finally I saw the TPS sensor glitching from about .75 volts up to 1.2 and as low as .4. It would stall and I'd loose coms.
Swapped it out and it was fixed.
Changing parts is easy, Troubleshooting is an art
  • rdhays99
9 years 10 months ago #4491 by rdhays99
Sorry for the long delay on an update on this truck. The PCM the customer purchased from Ebay was a remanufactured unit. I ordered a Chrysler remanufactured PCM, flashed the PCM and all is good now. According to my local Dodge dealer, the PCM for this truck was used on a 2002 model year only. I hate when people get Ebay parts, they may fit but not function correctly. Thanks for everyone's input on this truck that had me at my wits end.
9 years 10 months ago #4494 by Noah
Thanks for posting the fix on this one!
