98 Accord no start.
  • Bigfoote13
  • Bigfoote13's Avatar Topic Author
  • 7073910577
8 years 4 months ago #21411 by Bigfoote13
98 Accord no start. was created by Bigfoote13
Hi all, I have this 98 Honda Accord that doesn't start. It has good spark at the coil inside the distributor. the distributor cap and rotor all ohmed out okay but no spark coming out of the cap or through the wires to the spark plugs. Seems really weird but why would it not produce any spark out the cap when everything inside is okay? Like I said the coil inside produces a nice healthy yellow Spark. Has no codes and I do get an RPM signal. Any suggestions are helpful, thanks. Doug
8 years 4 months ago #21424 by The Auto Tech
Replied by The Auto Tech on topic 98 Accord no start.
How does the rotor look? Have you confirmed spark coming from the rotor or directly at the coil?
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
8 years 4 months ago #21426 by ScannerDanner
Replied by ScannerDanner on topic 98 Accord no start.
Bigfoote13 wrote: Hi all, I have this 98 Honda Accord that doesn't start. It has good spark at the coil inside the distributor. the distributor cap and rotor all ohmed out okay but no spark coming out of the cap or through the wires to the spark plugs. Seems really weird but why would it not produce any spark out the cap when everything inside is okay? Like I said the coil inside produces a nice healthy yellow Spark. Has no codes and I do get an RPM signal. Any suggestions are helpful, thanks. Doug
How far of a gap will the spark jump when testing it right at the coil? It should jump almost an inch
Don't be a parts changer!
  • Bigfoote13
  • 7073910577
8 years 4 months ago #21427 by Bigfoote13
Replied by Bigfoote13 on topic 98 Accord no start.
Hey thanks for your reply. I haven't checked the rotor yet haven't taken it off yet but I will today. And I was actually thinking of you Paul when I was doing that. It jumps plenty far. I guess the rotor can direct the spark down to the distributor shaft if it's burned through.
Doug
  • Bigfoote13
  • 7073910577
8 years 4 months ago #21431 by Bigfoote13
So it was the rotor. Even though it showed no signs of arcing through put on a new rotor and it runs great. Learn something everyday, thanks again.
