Clutch fluid Leak From Transmission weep Hole
- scorpiomaniac
8 years 4 months ago - 8 years 4 months ago #21447
by scorpiomaniac
Clutch fluid Leak From Transmission weep Hole was created by scorpiomaniac
I got an other issue last day. My clutch was not working, when ever I press the clutch it presses but doesn't comes back. When I checked my clutch fluid level, there was no fluid in it . Fine. I filled the clutch fluid back in and I bleed clutch fluid and clutch was working fine. But as soon as I cranked the engine, I found that the whole clutch fluid was leaking through the transmission weep hole. When I stops the engine, dripping stops. So My question is , Is the problem related to clutch release bearing or the oil seals .
Last edit: 8 years 4 months ago by scorpiomaniac.
- Ben
- Thank you received: 215
8 years 4 months ago #21453
by Ben
Replied by Ben on topic Re:Clutch fluid Leak From Transmission weep Hole
What year make model of vehicle is it? Either way when your inside I would replace the slave cylinder and inspect everything else
8 years 4 months ago #21457
Replied by Andy.MacFadyen on topic Clutch fluid Leak From Transmission weep Hole
No short cut, gearbox will have to be dropped and a new slave fitted, really advisable to fit a new complete clutch. If the car is a Ford diesel and has a Dual Mass Flywheel also check for metal debris on the starter drive and excessive lost motion in DMF
8 years 4 months ago #21468
Wow, I had no idea Ford was into dual mass flywheels on their diesel cars.
If it's a concentric slave, then yeah, the trans has to come out for replacement.
Replied by Tyler on topic Clutch fluid Leak From Transmission weep Hole
Andy.MacFadyen wrote: No short cut, gearbox will have to be dropped and a new slave fitted, really advisable to fit a new complete clutch. If the car is a Ford diesel and has a Dual Mass Flywheel also check for metal debris on the starter drive and excessive lost motion in DMF
8 years 4 months ago #21508
Ford Europe have been fitting DMF since the mid 1990's, of all the companies that fit them only Ford seem to have major issues with them. They became slightly more reliable after around the 2002 model year but there is a market for solid flywheel conversions. The first early warning is usually starter problems at around 60,000 to 80,000 miles due to the starter drive clogging up with metal debris from the DMF. Complete DMF failure 10,000 to 20,000 miles later.
Time to create page: 0.260 seconds
