98 Honda CR-V 2.0l hesitation under load.
  • Jonnyv
  • Jonnyv's Avatar Topic Author
8 years 4 months ago #21745 by Jonnyv
I’m working on my crv. It was driving fine until one day it started hesitating under acceleration. MIL came on for p0300. I have fuel and I have spark. Fuel pressure is at about 45-50psi. Check compression at each cylinder and all are within spec. Did a leak down test on wash cyclinder and they call passed. I checked timing and engine is still in timing. Any input would be greatly appreciated. Thanks!!
8 years 4 months ago - 8 years 4 months ago #21750 by Andreastech
Replied by Andreastech on topic 98 Honda CR-V 2.0l hesitation under load.
Based on your P0300 ...
What kind of ignition coil you have ??
COP (coil over plug) ???
1 coil and distributer ???
2 coils fires as a pair cylinders ??
btw ... check spark under load, like on a snap throttle, not at idle
If your misfire is under load ... you have to find it under load
soapy water + test light and a few snap throttle are some basics for that test
If you not feeling a single cylinder misfire ... and you feeling a no acceleration / low power etc ...
take a look at your exhaust
Last edit: 8 years 4 months ago by Andreastech.
8 years 4 months ago #21850 by Noah
Good advice about checking the spark under load ;)
This is video of a Honda intermittently losing spark. This one has an external coil,(5 plug wires on the cap) I think your CRV has it in the distributer cap, (4 plug wires on the cap) but I could be wrong about that.
And this one I believe is more like your system, but it is a no start. It is a good video showing the checks on the distributer with a test light and a scope.
Time to create page: 0.263 seconds
