P0175 Bank 2 rich
  • tyler n chelsey.pachernegg
  • tyler n chelsey.pachernegg's Avatar Topic Author
10 years 3 weeks ago #2465 by tyler n chelsey.pachernegg
P0175 Bank 2 rich was created by tyler n chelsey.pachernegg
I have a 2006 Jeep Commander 4.7 V8 that recently threw a p0301 cylinder one misfire. I changed spark plugs thinkin maybe that was issue only then to throw a p0175 bank 2 rich code and no longer the cylinder misfire. Idle is very rough like its chugging especially in reverse and drive. Very limited power it only goes up hill if i floor it and even then it hesitates to get there. Ive replaced both O2 sensors up and down on bank 2, changed oil, tested each coil on plug, and took off throttle body and cleaned it as well as the TPS. Another thing when i am out of gear and rev the accelerator it it wont go above 4000 rpms.
10 years 3 weeks ago #2467 by matt.white
Replied by matt.white on topic P0175 Bank 2 rich
What is bank one showing for fuel trims?
Can you do a back pressure test on bank 2?
What are trims at idle and when it's at 3000?
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
10 years 3 weeks ago #2473 by cheryl hartkorn
Replied by cheryl hartkorn on topic P0175 Bank 2 rich
have you done fuel injector balance testing?
  • cheryl hartkorn
10 years 3 weeks ago #2474 by cheryl hartkorn
also ive seen that era of jeeps have valve problems. id do a compression test on that side of the motor.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
10 years 3 weeks ago #2475 by ScannerDanner
Replied by ScannerDanner on topic P0175 Bank 2 rich
tyler n chelsey.pachernegg wrote: I have a 2006 Jeep Commander 4.7 V8 that recently threw a p0301 cylinder one misfire. I changed spark plugs thinkin maybe that was issue only then to throw a p0175 bank 2 rich code and no longer the cylinder misfire. Idle is very rough like its chugging especially in reverse and drive. Very limited power it only goes up hill if i floor it and even then it hesitates to get there. Ive replaced both O2 sensors up and down on bank 2, changed oil, tested each coil on plug, and took off throttle body and cleaned it as well as the TPS. Another thing when i am out of gear and rev the accelerator it it wont go above 4000 rpms.
First, there is a rev limiter, so not being able to rev above 4000 rpm in park or neutral is normal.
Second, when did you replace these O2 sensors? What type of O2 sensors did you use?
Third, have you seen these videos?
Don't be a parts changer!
