2006 Trailblazer 4.2 P0171 - FIXED
- Tutti57
- Thank you received: 254
Any other ideas or common issues you've seen on these engines?
If you haven't already, maybe eyeball the MAF anyway. I've had debris stuck in the sensor that moves around and changes the reading accordingly.
- Tutti57
- Tutti57
- Tutti57
There's a couple PCV hoses underneath the intake 'box' that are easily missed if it's been reinstalled recently. But, leaving those off almost always generates a bigger trim issue than what you're seeing.
Any chance that E85 ended up in the tank at some point? If it did, and they've filled the tank with regular gas since then, you could be looking at a mix of the two. Fuel quality issues will tend to skew trims at all load ranges, in my experience.
- Tutti57
There are now some cam codes and I don't recall exactly which ones, maybe p0011? but the oil level was a little low and way past a change. Im doing a bunch of things on this truck but plan on starting it back up tomorrow to run the drive cycle and try to inspect it.
- Tutti57
- Tutti57
- Tutti57
- Tutti57
- Tutti57
If I give it some throttle, ltft drops down to 10% but stft goes up to 9%.
I think I'm going to pull the purge valve off tomorrow during lunch and vacuum test it.
Any other ideas it things I should recheck?
- Tutti57
- Tutti57
I'm going to watch mondes video in a minute but I feel like the trims went up recently after the tank dropped under 80% and the monitor was running.
- juergen.scholl
- Active partschanger
- Thank you received: 462
in your very first post you also mentioned the tsb on clogged injectors. I have seen the injectors clogged on thes 4.2 engines OFTEN. Did you ever do an injector pressure drop test?
- Tutti57
- Tutti57
I did have a p0014 and saw that the actuator was not really moving when I out power to it, so I replaced it. After a few drive cycles I see that the code is pending again, so I'll have to look into that.
