[FIXED] 2000 Chrysler Town & Country 3.3 No crank/No start
- popoften
- Thank you received: 22
Working at the Starter relay, there is 12V at all times to the load supply relay contact 30. Relay contact load ground side contact 87 shows a good path to ground through starter motor. There is 12v to the supply side control contact 86 with key on START, but kind of a "fuzzy" ground at contact 85, which is grounded at the PCM.
When I supply ground to relay contact 85, the engine will crank but I still get no spark (verified by checking voltage of input wires to coil packs)
So, at this point, given the fuzzy ground, and the non-illumination of the CEL, and the bad PCM-supplied ground, and the fact that supplying a good ground restores the crank, I am suspecting a bad PCM.
I have also checked the 5v reference circuit at the TPS and MAP sensors with KOEO, and it reads 0 volts at the sensors. I also back probed the 5v reference wire at the computer, and it reads 0 volts there as well.
I have checked the PCM ground wires that come out of the back of the PCM to the body ground, and they show as good grounds.
So, to my untrained eye, it seems we are looking at a bad PCM. What do you guys think? What else should I check?
I saw that you've gone over the PCM grounds, but I'd suggest going over the power circuits, too. I know, it doesn't make sense that a lack of ground is caused by a power supply issue, but I still feel that it's worth checking. It may be that only part of the PCM is getting powered up, causing outputs to act weirdly. Could definitely explain the 5V reference issue, too.
The fuzzy ground from the PCM kinda makes me suspect a voltage drop issue, but that wouldn't explain the 5V reference... Perhaps worth rechecking that circuit at the PCM? Include pin fitment in there, too.
- cheryl hartkorn
- Thank you received: 130
That would be my next move!cheryl hartkorn wrote: you could cut the 5 volt ref wire close to the pcm and then check for 5 volts. maybe a bad sensor pulling it to ground. thatd save you time from possibly unplugging all the sensors and still have 0 volts
- popoften
- The Auto Tech
- Thank you received: 8
- ScannerDanner
- Away
- Administrator
- Thank you received: 500
Don't be a parts changer!
- popoften
popoften wrote: I cut the 5V reference wire near the PCM, and it shows .1 volt with negative polarity on my Power Probe. I am going to double check a few other things, but this is looking like a bad PCM to me...
The green 'negative' LED lit up? Hmmmmm, sounds like it's finding a path to ground somehow... Anyway, it's not 5V, so that takes sensors out of the equation.
Sure is looking bad for the PCM. Powers, grounds, then stick a fork in it
- popoften
- popoften
That Cobalt was a good demonstration of how to check a PCM.
popoften wrote: Installed the new PCM today, and the car fired right up and ran like a champ. THANK YOU, guys, for your help on this. And scannerdanner, your Cobalt videos really demystified making a call on a bad PCM.
Sweet! Thanks for letting us know where this one ended up
I still think it's crazy how the Power Probe showed ground on the 5V reference wire... Maybe it got shorted to ground on the board itself? :huh:
- popoften
