Mercedes 500 SEC ignition problems
1 year 7 months ago #85382 by petax
Mercedes 500 SEC ignition problems was created by petax
Hello!
I have a 1983 Mercedes 500 SEC V8 where the ignition rotor keeps melting. It is melting according to the picture but not more than that, so I can still drive the car and it runs good. It happened again when I changed to a new rotor. I guess it should not be like this and I would like to troubleshoot. All pictures are in this link:
postimg.cc/gallery/m9tSXjs
The ignition system is a traditional rotor distributor and a coil. The ignition trigger is transistorized. See picture from the engine workshop manual. The rotor, distributor and spark plugs are new and the coil seems to be in good condition. I have measured resistance on everything in the ignition system and it is within spec acc to workshop manual. Wires, coil, distributor, spark plugs etc. I have a suspicioun that it could be old ignition cables that is causing the problem. Maybe the spark takes a different route sometimes or build too high energy before release which creates heat that melts the rotor? Maybe too high inductance or shorting to ground?
I have measured on the ignition cable between the coil and distributor with an oscilloscope (picoscope 2204A) with a hantek HT-25 pickup. See the snapshots where the first seems quite normal(?) but the other ones looks like something is wrong.
Best regards
