95 CHEVY S10 VACUUM LEAK
- gilbert
- Thank you received: 15
8 years 3 months ago - 8 years 3 months ago #22395
by gilbert
95 CHEVY S10 VACUUM LEAK was created by gilbert
God bless you my brothers and sisters.
I got this s10 with a vacuum leak it turned out too be the brake booster. I put one from the junk yard and took care of the leak . Now I get loss of power black soot on spark plugs. I did find that a injector is leaking by the way it's TBI the question is if the injector is leaking and it has a vacuum leak will it run fine? Then I fix the leak andthen I get loss of power and back firing.
Thank you for your help.
Last edit: 8 years 3 months ago by gilbert.
- Ben
- Thank you received: 215
8 years 3 months ago #22406
by Ben
Replied by Ben on topic Re:95 CHEVY S10 VACUUM LEAK
What load is your misfire/backfire? Does it do it at idle and acceleration? These plastic lines to the injectors are prone to wearing on the aluminum intake and leaking inside the intake inspect all of your injector hoses while you have it apart
- gilbert
8 years 3 months ago #22414
by gilbert
Replied by gilbert on topic Re:95 CHEVY S10 VACUUM LEAK
Hey Ben it's at acceleration and it's not all the time. I already fixed the leak on the injectors. It runs better but it still has a backfire at hard acceleration not all the time.
- Ben
8 years 3 months ago #22425
by Ben
Check your fuel pressure make sure it goes up on a wide open throttle snap pop off injectors are very picky on having enough fuel pressure
The following user(s) said Thank You: gilbert
