Need help with diagnosing IAC
- jerry r
8 years 2 months ago - 8 years 2 months ago #22535
by jerry r
Need help with diagnosing IAC was created by jerry r
2005 Ram 1500 4.7. no codes idle jumping up to 2000 rpm in any gear , due to IAC but if I snap the throttle or if I tap on the throttle body it sometimes goes down . spayed brake clean looking for vaccum leaks found none ,tested with a snap on scanner it lets me control the Iac also reset the iac it corrected it but started acting up again, tested with a scope an it shows an intermittent erratic waveform that sometimes is dropping out.I believed it to be a shorted coil in the IAC valve and replaced it to no avail. what an I missing. Thanks for the help in advance ,also shifting problems intermittently like its not finding gears mostly after stopping at a light .
Last edit: 8 years 2 months ago by jerry r.
- Ben
- Thank you received: 215
8 years 2 months ago #22540
by Ben
Replied by Ben on topic Re:Need help with diagnosing IAC
Take a look at your tps voltage on your signal wire or tps% pid my bet is it thinks your at partial throttle and it's trying to get the rpm up to the desired throttle position assuming you don't have a vacuum leak
- jerry r
8 years 2 months ago #22544
by jerry r
Replied by jerry r on topic Re:Need help with diagnosing IAC
I checked the tps pid and it looks good
8 years 2 months ago - 8 years 2 months ago #22545
Replied by Chad on topic Need help with diagnosing IAC
What is your IAC step count when this is happening?
Can you post a waveform of this?
jerry r wrote: tested with a scope an it shows an intermittent erratic waveform that sometimes is dropping out.
Last edit: 8 years 2 months ago by Chad.
- Ben
8 years 2 months ago #22563
by Ben
You said tps pid looks good what was it's %?
- jerry r
8 years 2 months ago - 8 years 2 months ago #22565
by jerry r
it ended up being the tps thank for your help
- Ben
8 years 2 months ago #22579
by Ben
Glad you got it fixed. for reference what was the throttle % closed throttle
- jerry r
8 years 2 months ago #22606
by jerry r
when it acted up the tps % was up to 20
