2009 MiniCooper Clubman 1.6L (Model R55, N12)
  • robert.lesaca
  • robert.lesaca's Avatar Topic Author
8 years 2 months ago #22619 by robert.lesaca
2009 MiniCooper Clubman 1.6L (Model R55, N12) was created by robert.lesaca
I just got this car from a mechanic friend who said DLC showed 287D VANOS Inlet actuator movement/actuator stop. Being so cramped an engine compartment, I could not even unplug to check wires. So I ended up removing the VANOS solenoid, and only then was I able to unplug the connector. I directly activated the solenoid via battery and was working. In the absence of a wiring diagram, I have not check wiring integrity. Has anybody come across a problem like this with a MINICOOPER CLUBMAN? Is this related with tythe CMP/CKP sensors? What direction can be suggested to start with. BTW the way, owner said that prior to the check engine lights, she filled up oil which was very very low. It was after a few days filling up the required amount did the DLC come on...
8 years 2 months ago #22626 by Chad
287D = p0012
  • robert.lesaca
8 years 2 months ago #22628 by robert.lesaca
Replied by robert.lesaca on topic 2009 MiniCooper Clubman 1.6L (Model R55, N12)
Thanks for the diagram. It looks like the solenoid is powerside. I remember a video by Paul, I believe a Subaru VTEC. The owner has decided to leave the car with me. I will view that video and take it from there. I guess I have to scope both CKP/CMP for relationship as well check timing too. I will give an update on how it goes, with fingers crossed.
The following user(s) said Thank You: cesar.m
  • robert.lesaca
8 years 2 months ago #22644 by robert.lesaca
File Attachment:
File Name: 2009MiniCl...2.psdata
File Size:1,670 KB
This the waveform I just did...i cannot find a similar waveform anywhere. So Im presuming this is a good waveform.
  • robert.lesaca
8 years 2 months ago #22735 by robert.lesaca
HELP...Hi Tyler, Noah or anyone out there who has experienced uploading pictures.
I have uploaded pictures in the past but suddenly I cant. How come?
  • robert.lesaca
8 years 2 months ago #22742 by robert.lesaca
These are the waveform I got for the #1 in-cylinder compression and coil signal...at a glance, TDC is occuring before spark event (per computation abut 2.3 degrees of crankshaft rotation per sec). I dont know of the vehicles exact timing in degress but per Paul it should occur close to zero degrees, if not zero).
  • robert.lesaca
8 years 2 months ago #22743 by robert.lesaca
Likewise, here are the Intake and Exhaust VANOS waveform. I noticed that there was no change in frequency when revving up the engine.
Starting from a cold engine, as soon as RPM drops from 1100 RPM to about 1000, engine would experience a "hiccup" and set a fault code of 287D (PO012) - Intake Vanos solenoid actuator problem. The Intake Vanos solenoid was changed before hand, but as mentioned frequency does not change despite rev up.
  • Landroverman1958
  • Landroverman1958's Avatar
8 years 2 months ago #22745 by Landroverman1958
Replied by Landroverman1958 on topic 2009 MiniCooper Clubman 1.6L (Model R55, N12)
Can you access scan data?so that you can see what the valve advance is,or doing,any bi directional actuator tests available,any pids for desired verus actual,position.
  • robert.lesaca
8 years 2 months ago - 8 years 2 months ago #22750 by robert.lesaca
at the moment these are all the remaining waveforms I have and the corrresponding changes in Voltage including the point, at 3.68 secs, frame 2, where the engine would "hiccup" momentarily setting PO0012/287D
Unfortunately the owner had to pick up the car as she needed it for work.
Last edit: 8 years 2 months ago by robert.lesaca. Reason: pdf file not visible...
  • robert.lesaca
8 years 2 months ago #22768 by robert.lesaca
KOEO, the exhaust VANOS solenoid control wire showed 1.56 V plugged-in; and 1.93 unplugged, other wire read 0V plugged-in.
the intake VANOS control wire (which I was not able to save) i remember exhibited the same voltage reading, plugged-in and unplugged...
  • robert.lesaca
8 years 1 month ago #23220 by robert.lesaca
UPDATE
I spoke with the owner and as advised, they went to the dealership regarding the problem. Dealer updated software that reconfigured the whole timing system with the newly installed intake VANOS solenoid. This vehicle is considered FIXED
  • Landroverman1958
8 years 1 month ago #23221 by Landroverman1958
Good to hear the problem is resolved,pity you cant get somw after wave forms to see what the timing is doing,well done.
  • robert.lesaca
8 years 1 month ago #23230 by robert.lesaca
at the first opportunity, i wl talk to the owner so I can a post a timing waveform after the the software upgrade....
The following user(s) said Thank You: Agnewsautos
