2010 dodge charger sxt 3.5 misfire counters
  • cheryl hartkorn
  • cheryl hartkorn's Avatar Topic Author
8 years 2 months ago #22687 by cheryl hartkorn
2010 dodge charger sxt 3.5 misfire counters was created by cheryl hartkorn
im having a misfire isssue cylinders 3 and 5. swapped everything over plugs coils injectors over to cylinders 2 and 4.., the misfire test in the snap on scanner shows misfire as global disabled. how does it get reset or anything?? trying to help a friend out to see if the misfire moved. it is worse at idle better at off idle..
8 years 2 months ago #22688 by BowtieGuy18
Replied by BowtieGuy18 on topic 2010 dodge charger sxt 3.5 misfire counters
Did it have a check engine light on and you erased it? If so you may have to drive the vehicle for a short period of time to reboot everything.
8 years 2 months ago #22692 by Tyler
Does your friend have access to a smoke machine? I've see the lower intake gaskets suck in on those before, amounting to a vacuum leak on a single intake runner. It's usually tough to get water in the right spot to catch it. Other than that, the only choice is to pull the upper intake for a visual.
  • cheryl hartkorn
8 years 2 months ago #22702 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2010 dodge charger sxt 3.5 misfire counters
brand new fel pro gasket. torqued intake to spec. were trying to get the misfire counter to read to see if the miss moved with him swapping the coil plug injector. but it says its globally disabled
