Cam code
  • autojoe
8 years 2 months ago #22902 by autojoe
Cam code was created by autojoe
I thought Paul stated in one of his videos that a faulty crank sensor could trigger a cam sensor code but may be mistaken. Thanks in advance. Joe
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 2 months ago #22916 by chief eaglebear
Replied by chief eaglebear on topic Cam code
i believe you are right i am not sure if he eluded to the fact that a faulty cam sensor will cause a crank sensor code or vise versa the crank sensor being a critical input a correlation procedure might help not sure i guess as long as you can verify the crank signal isnt happening at all or at least not making it to the computer
  • chief eaglebear
8 years 2 months ago #22917 by chief eaglebear
with more info the people on this forum will be happy to help i.e. make of car any possible codes or a description of symptoms from whay your describing you cant get the car started right it probably cranks wont start : 0
  • autojoe
8 years 2 months ago #22925 by autojoe
Replied by autojoe on topic Cam code
I was just curious of the possibility of this happening. I was trying to find the particular video..... If Paul would monitor this site I'm sure he would know.
8 years 2 months ago #22927 by Ben
Replied by Ben on topic Re:Cam code
It may be possible but would largely depend on the vehicle and the code to know what the code set criteria is (it may be possible on some vehicles but not at all possible on others)
8 years 2 months ago #22983 by Ben
Also here's the video (It happened to be in my recommended....
The following user(s) said Thank You: autojoe
  • autojoe
8 years 2 months ago #22985 by autojoe
Replied by autojoe on topic Re:Cam code
Thank you.... This is a faulty cam sensor causing a crank sensor code.... It can probably work just the opposite.
8 years 2 months ago #23013 by Ben
Try this 1 I didn't watch it. but I can tell you any shorted sensor sharing the same 5v ref line can cause codes for any other sensor on that 5v ref that's why we check 5v ref whenever were dealing with no starts or whenever dealing with fault codes related to sensor on the 5v ref to verify a sensor is not pulling the whole line down.
