07 Cadillac dts. No crank. No communication at data link connector. Help please
- PEric
There was a 15 amp blown fuse in the engine compartment fuse block, although I did not note the circuit. I replaced the fuse. Nothing changed. I also replaced a blown 20 amp fuse in the fuse block under the rear seat #F23 LTR/CNSL.
I have checked the engine block for ground and all grounds under hood show 12.6 volts. I connected a scan tool to DLC, and it read no communication. Just to be sure, I also connected a basic code reader which also read no communication.
I am stuck on where to go from here.
May end up in divorce court if I can't make this car run. Please help.
PEric wrote: all grounds under hood show 12.6 volts
You have a bad engine ground. Check the main ground cable between the battery and engine block.
- Msuits85
- Msuits85
- fall7rise8
- Thank you received: 2
Msuits85 wrote: I have the exact same problem after engine replacement on a Cadillac XLR has anybody come up with a solution for what was going on here I've checked everything five times over all my grounds are good still can't get the car to spin over or communicate with the scanner
Would you be willing to take some voltage measurements at the DLC?
- Matt T
- Thank you received: 276
Is this no comm with a scan tool or no comm with a diy level code reader? If it's a scan tool try manually entering the VIN.
- 2backyard.mechanics
- Monde
- Thank you received: 43
Do you have a scanner that can read more than 1 module? Do you have access to a wiring diagram that can tell us if there is a gateway on the high speed can or not?
Have you checked the high speed can for the 2.5 v on both can h and can low when no data is transmitted onto the bus?
Have you checked the terminating resistors at one of the most accessible module?
Start with a scanner that can read more than one module and a wiring diagram of the data lines.
