Question on sensors
- Ash03
- Thank you received: 6
8 years 1 month ago #23153
by Ash03
Question on sensors was created by Ash03
Hey guys i have a few questions of some circuits that i am unfamiliar with..
1. 2006 vw polo 9n 1.6i
* cam sensor circuit
Its a hall effect 3 wire sensor.. from my knowledge on it, it has a 5v ref, a ground, and signal. How does the signal wire have battery voltage on it? How does a 5v sensor output more than 5v? Confused! I dont have a scope so i can't give a waveform, and the battery was low reading 10v only.. the sensor works, it's just something i dont understand.
* this car will not pulse the injectors or give it a constant 12v if the fuel pump doesn't work. Clever engineering?
Got this 1 fixed, it was faulty fuel pump wiring..
2. 2013 Audi A4 1.8tfsi 8k chassis
* this car has 12 fault codes all concerning 5v sensors. I was thinking along the lines of a shorted out sensor. I decided to test the 5v ref on 2 of the map sensors:
Sensor 1: has 5 volts when unplugged, plugged on and back probed it has 1v.
Sensor 2: has 5v when unplugged, plugged on and back probed it has 0v.
This really baffles me as the car was running normal with no problems. It began to have a rough idle, then when parked off and started again, it just wouldnt rev at all and the idle fluctuates badly around 800-1000rpm
Im hesitant to experiment on this 1, too new for my liking. I will post the fault codes below tell me what u guys think..
15472 - Engine Coolant Level Sensor/Switch P2556 00 [039] - Electrical Malfunction Not Confirmed
15462 - Control Circuit for Coolant Bypass Valve P2681 00 [047] - Open Cricuit Confirmed
17789 - Insufficient Engine Cooling / Coolant Flow P00B7 00 [035] - - Not Confirmed -
15447 - Thermostat for Transmission P19A2 00 [035] - Open Circuit Not Confirmed
17178 - Databus U1123 00 [035] - Received Error Message Not Confirmed
15197 - Intake Manifold Flap Position Sensor (Bank 1) P2014 00 [039] - Electrical Malfunction Not Confirmed
15373 - Sensor Reference Voltage A: Circuit P0642 00 [175] - Low MIL ON - Confirmed
15349 - Throttle Body Actuator Bank 1 (J338) P0638 00 [032] - Implausible Signal Intermittent - Not Confirmed
15341 - Throttle Body Actuator Bank 1 (J338) P0638 00 [167] - Implausible Signal MIL ON - Not Confirmed
15202 - Actuator Module for Turbocharger 1 P00AF 00 [109] - Stuck Confirmed
14846 - Turbocharger Boost Control Position Sensor Circuit P2563 00 [175] - Implausible Signal MIL ON - Confirmed
14847 - Turbo/Super Charger Boost System P2263 00 [047] - Performance Confirmed -
14833 - Internal Control Module P0606 00 [039] - Processor Fault Not Confirmed
15122 - Manifold / Barometric Pressure Sensor (G71) / (F96) P0106 00 [038] - Implausible Signal Intermittent - Not Confirmed
15214 - Manifold Pressure / Boost Sensor (G31) P0236 00 [032] - Implausible Signal Intermittent - Not Confirmed
Sent from my SM-J500F using Tapatalk
- derekoliveira
8 years 1 month ago #23162
by derekoliveira
Replied by derekoliveira on topic Question on sensors
Audi A4- check main plug on the ECM or same plug between components, sensors and ECM! look for corrosion, moisture, etc. Can be ECM problem but is worth it to check frist of all!?
It is to much dtcs at diferent components and sensors for all them fail at the "same time"...
- Ash03
8 years 1 month ago #23163
by Ash03
Replied by Ash03 on topic Re:Question on sensors
Il get my friend to check the ecm plug..
Yeah all those problems at once is what made me look at the 5v ref, and i dont understand how the voltage is dropping though.. its quite unlikely that both map sensors fail at the same time.
On the other hand, i have done some research and checked these ecu's fail alot. But thats not enough proof to call a dead ecu
- derekoliveira
8 years 1 month ago #23166
by derekoliveira
Replied by derekoliveira on topic Re:Question on sensors
And 1 faulty component can lead to to other fault or dtcs.
Can be only software updating...now i am just rambling
- Missioner
8 years 1 month ago #23184
by Missioner
Replied by Missioner on topic Re:Question on sensors
Replying to the Audi problem.
Have you checked the basics? Battery poles, Earth points, connectors, etc.
Establish that the battery is good and that all the main points where electricity is travelling through the car are clean and secure.
To illustrate what I mean, I had a customer come in a few days ago with a 1er which refused to start and a dash full of lights. He asked me for a new battery for the car. I checked his existing one which was fine. Cleaned the pole, the terminals and the battery tray. Plugged it all back together and the car starts and half the warning lights went away. Another one is on certain 3er's there is a common earth for all the sensors and injectors in the engine harness. The join is inside the injector harness plastic box wrapped in cloth tape. When the engine gets washed water stays in the box causing the joint to corrode and messing all the signals up for the sensors and triggering the EML. Saw an engine get rebuilt due to this wiring problem.
My point is that the cause is usually simple in nature and requires a systematic approach to diagnose. Stop looking at the computer screen full of trouble codes and look at the car. A scan tool is just that, a tool. It can't think for the technician.
Start at the beginning and work through each part of the system step by step and you can solve the problem.
- Ash03
8 years 1 month ago #23187
by Ash03
Thanks for the reply missioner.
Honestly i didnt check anything on the car, i was just offered a scan because the owners scantool wasnt working.
After having a good look at the log, i have asked the guy to test the 5v ref because most if not all those codes are related to the 5v circuits, and this code gave me some direction:
On vws i have noticed if theres a battery terminal problem it almost always throws the terminal 30 dtc, im not saying u wrong - its worth the check..
I didnt ask him to check ground points either because he did check sensor grounds and there wasnt any voltage drop on the ground wires (i believe if ecu ground was bad, the sensor grounds should have a voltage drop across it..?).. again, its worth the check.
I agree about the scantool, i understand its just a guide.
- Ash03
8 years 1 month ago #23241
by Ash03
Ok so i had a look at the car myself today, as i thought - the 5v circuit was shorted.
The cause of the short was from a leaking waterpump, the connector was full of water and corroded.
Unplugged the connector at the water pump, dried it abit. Started the car and everything seems to be working, no codes besides the water pumps coolant flow. Lucky doesnt seem like theres any ecu damage.
Happy with the result, my friend is happier that that ecu is not fried haha
