2019 Honda CRV 2.4 liter alternator appear to be charging sometimes
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
1 year 6 months ago - 1 year 6 months ago #86956 by Mechanic 350
With this vehicle, I've experienced a dead battery already.  When I installed the new battery and I'm looking for charging voltage of 14 volts +, I don't see it unless I put a load on the alternator by putting the a/c on or putting the headlights on.  Is this normal for honda?  I've never experienced the alternator not showing that it's charging the battery unless a load is place on the alternator.  I'm afraid of another bad battery.  Is my assessment wrong?  By the way, I haven't looked for any battery drains.  yet.
forgot to mention, the alternator has only ONE wire.  yellow in color
Last edit: 1 year 6 months ago by Mechanic 350.
1 year 6 months ago #86957 by Monde
1 wire alternator? Alternator usually has at least 3 wires. Sense, Lamp, Field and feedback.
1 year 6 months ago #86959 by Tyler
Entirely normal for that year of Honda.
The Honda 1-wire alternators are using a LIN bus for communication between the ECM, the alternator and the battery current sensor. Those systems will use a low charge rate until the current demand goes high enough, just like you saw.
The older four-wire systems that Monde mentioned also have a low charge rate mode, but the newer 1-wire systems are much more aggressive about using the low charge rate whenever possible.
The following user(s) said Thank You: Mechanic 350, Monde, Lupe
1 year 6 months ago - 1 year 6 months ago #86960 by Monde
I was planning on looking at the diagram and the description and operation tomorrow at work. Thank you, Tyler, for your valuable input.
Last edit: 1 year 6 months ago by Monde.
  • Mechanic 350
1 year 6 months ago #86965 by Mechanic 350
But the battery takes a hit then. Meaning is not being charged until there’s a demand. The battery lasted 3 years only. Thanks for your insight Monde and Tyler. That puts my mind at ease.
  • Mechanic 350
1 year 6 months ago #86966 by Mechanic 350
Tyler can you direct me to a video that would teach me the operation of the Lin bus wire, alternator, and current sensing circuit? Thank you
