Backup Camera - Test if Bad
  • dkggpeters
  • dkggpeters's Avatar Topic Author
8 years 1 month ago #23434 by dkggpeters
Backup Camera - Test if Bad was created by dkggpeters
I have a nonworking backup camera on a 2014 Subaru Legacy 2.5 in which shows as not being connected on the diagnostic screen on the Harman Kardon stereo/navigation unit. The camera has 4 wires in which one is 6 volt power, one is the video signal, one ground for power/video signal, and one ground which is shielded around the 3 wires. I hooked up the Vantage Pro to the power and get a 6 volt power signal for about one second while the unit is powering up and then it drops to zero volts. I get no signal over the video wire at any time. I am guessing the the unit supplies power to the camera and is looking for some confirmation of a video signal which is not happening so the power is cut off. I have not checked continuity on the wiring yet for the video signal and I do have continuity on the grounds. Since I do get power for a brief period of time when booting the system up, I am assuming that the power wire is fine.
I am thinking it is just a bad camera and was wondering if anybody knows of any tests to confirm this.
8 years 1 month ago #23437 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Backup Camera - Test if Bad
Any aftermarket hardwired backup cameras I have worked on 12v battery voltage from the reverse lights. To save wiring the co-axial video cable has a splitter at the rear and has 12v from the reverse light cluster piggy backed on top of the video signal a the front this another splitter with a red wire that goes the reverse wake-up terminal on the DIN connector at the back of the head unit.
  • dkggpeters
8 years 1 month ago #23438 by dkggpeters
Replied by dkggpeters on topic Backup Camera - Test if Bad
This is not an aftermarket camera and was factory installed when we bought new. The navigation unit triggers the camera when you go into reverse. There is a test function on the unit and when the car is put into reverse the unit recognizes that it is in reverse and should trigger.
I just thought of something. I should check the unit to see if a signal is in fact sent out when I put the car into reverse to isolate if it is the unit or camera that is an issue. It just came to me as I was writing the first paragraph above.
