Engine stalls when cold
  • mh70ss
  • mh70ss's Avatar Topic Author
8 years 1 month ago #23457 by mh70ss
Engine stalls when cold was created by mh70ss
I have a 1994 Camaro LT1 (350 ci) w/multi-port injection. Whenever I try to start the engine when it is cold, it starts and then stalls immediately. It does this 3 times, before it will stay running. After that, it runs fine all day. It acts like an old carb engine when cold. Any ideas?
Thank you,
8 years 1 month ago - 8 years 1 month ago #23470 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Engine stalls when cold
Two things spring to mind.
(1) Check the fuel pressure at switch on and cold cranking also watch how quickly the pressure drops off when the key is switched off.
(2) Lack of cold start enrichment caused by an engine coolant temperature sensor issue.
Last edit: 8 years 1 month ago by Andy.MacFadyen.
  • mh70ss
8 years 1 month ago #23471 by mh70ss
Replied by mh70ss on topic Engine stalls when cold
Will do, thank you.
