Nissan coil over plug
  • Mrwoody
  • Mrwoody's Avatar Topic Author
1 year 6 months ago #87266 by Mrwoody
Nissan coil over plug was created by Mrwoody
2011 Altima 3 wire ignition coil. What is the voltage reading on the control wire key on engine off?
i know theirs battery voltage and ground.
i have a situation where im getting 4 different readings on the control wire, and  i know this isn’t right
2.5L
1 year 6 months ago #87476 by Paul P.
Replied by Paul P. on topic Nissan coil over plug
Are you using a DVOM?  If you are, the voltage will be anywhere from 0-5v (you could try max/min if your DVOM has it).   The DVOM is too slow to read the control signal.  It is a 5 volt square wave, an oscilloscope is required to view it. The other 2 pins are B+ and GROUND.
Never stop Learning.
