2004 F150 maf specifications
- fvalck
10 years 2 weeks ago #2993
by fvalck
2004 F150 maf specifications was created by fvalck
Hi to everybody, new to the forum and to the diagnostic. I'm looking for the specification of the drop in maf sensor on a 2004 5.4l.
So far I have negative long term fuel trims at idle and between 12 and 18 at 2500 rpm. The voltage koeo on the signal wire is 0.5. On koer the idle voltage is 0.7 and at 3000 rpm is 1.6. I already clean the maf and no change. Please help.
- cheryl hartkorn
- Thank you received: 130
10 years 2 weeks ago #2995
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2004 F150 maf specifications
what does the grams/second read at idle?
10 years 2 weeks ago #3000
Replied by Tyler on topic 2004 F150 maf specifications
I've got some known good data from an '05 F-150 5.4L I worked on recently:
www.scanshare.io/share/LSMwrX9cbEy44uGhy...12,26,27,28,29,30,31
Looks like the idle MAF voltage was .87V. If the MAF was causing the rich trims, then I figure your MAF voltage would have to be higher than that, not lower.
Cheryl, any luck on your F-150 with rich codes?
- cheryl hartkorn
10 years 2 weeks ago #3004
by cheryl hartkorn
reflashed it a couple weeks ago. haven't seen it since. didn't want to post the fix until it had a few weeks to see if the flash took care of it
10 years 2 weeks ago #3006
Sweet! Gotta tell matt.white that I won our bet
cheryl hartkorn wrote: reflashed it a couple weeks ago. haven't seen it since. didn't want to post the fix until it had a few weeks to see if the flash took care of it
- fvalck
10 years 2 weeks ago #3026
by fvalck
Replied by fvalck on topic 2004 F150 maf specifications
At 607 rpm the g/s is 5.37.
10 years 1 week ago #3047
Replied by Noah on topic 2004 F150 maf specifications
A quick hip-shot spec is 1g/s for every liter of displacement at idle..
So 5.37g/s is pretty close to the 5.4l displacement of the engine.
This isn't the best rule to follow, there are exceptions, but it can be useful..
