07 gt mustang 4.6
  • StewRam
  • StewRam's Avatar Topic Author
8 years 2 weeks ago #24078 by StewRam
07 gt mustang 4.6 was created by StewRam
Came from another shop. Parts cannon was loaded heavy on this one. P0345. Cmp sensor a bank 2 code. Mitchell in says it should have over 10 volts coming from pcm. Backed probed pcm and 0 volts. Customer ordered Pcm from Ford. I installed and programmed and code came right back. Scoped both cmp sensors, good waves. Back probed pcm and the wave form is real noisy. Any suggestions where it may be coming from? I'm checking the alternator tomorrow for ac voltage. Any suggestions will be appreciated.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 2 weeks ago #24081 by cheryl hartkorn
Replied by cheryl hartkorn on topic 07 gt mustang 4.6
unplug the alternator. i seen it before
  • StewRam
8 years 2 weeks ago #24134 by StewRam
Replied by StewRam on topic 07 gt mustang 4.6
UPDATE...... Bank 2 is out of time. Always check basics. I had a good wave from on bank 2, but never checked correlation to bank one. Someone had changed the phasers and was off by a couple of teeth. Car has 91000 miles, owner is going to go ahead and do the chains and HO oil pump. Did remove the serpentine belt no change. I am not sure how to attach the wave forms, if I figure it out I will post them.
