Ford Alterantor Issue Gen com and mon????
8 years 2 weeks ago #24095 by kerry
I have a 2008 ford expedition with 5.4 customer says hes's changed 3 alternators. now he brought it to me I looped Gen com and Gen mon wires and commanded output and my Gen mon is following so i have to believe the harness is fine. while running scanner shows a Gen command of 55 and Gen monitor of 100 Gen frequency on 00 and battery volts is 11.2 volts Any thoughts ?????
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 2 weeks ago #24099 by cheryl hartkorn
Replied by cheryl hartkorn on topic Ford Alterantor Issue Gen com and mon????
those systems are the smart charging system. to determine if its a control issue or alternator issue unplug the harness rev the motor to 3000 rpm a couple times. the system should default to 13.5 volts if the alternator is working...
8 years 2 weeks ago #24110 by Tyler
Replied by Tyler on topic Ford Alterantor Issue Gen com and mon????
Good move jumpering Gen-Com and Gen-Mon together. From here, I'd do as Cheryl suggested. If you don't see 13.5V, then it's still a bad alternator. Consider using a Motorcraft new or reman, if the owner hasn't already.
Power, ground and belt tension are good?
