2001 cl600 crank no start
  • Mike_dg2008
  • Mike_dg2008's Avatar Topic Author
8 years 2 weeks ago #24109 by Mike_dg2008
2001 cl600 crank no start was created by Mike_dg2008
So i have a 2001 Mercedes cl600 that cranks and no starts 80,000 miles. i have replaced the ignition control module because i had no spark and now I'm getting spark, also i have replaced the fuel pump. The fuel is getting to the fuel rail when i press on the valve gas shoots out of it, the issue I'm having is that injectors 1-5 are spraying and read 8.0 v when the key is turned and cranking the engine, injectors 6-12 read no voltage. i have swapped a good known ecu into the car with all the drive authorization components and still get the same issue, i have also replaced the throttle body since the ecu is throwing a codes:
P2032- m16/6r1 (throttle valve actual value potentiometer (p0120)
P2097- throttle valve jamming (iced up)
P202E- throttle valve actuator (P0120)
P2006-b2/5b1 intake air temperature sensor (p0110)
P20b8- camshaft hall sensor, left bank of cylinder (p0340)
replacing throttle body did nothing, Crankshaft sensor has also been replaced. Spraying some starter fluid directly into the throttle will occasionally start the engine. I'm not a tech but like to work on cars. I'm at a roadblock need someone to enlighten me! Thank you in advance.
8 years 1 week ago - 8 years 1 week ago #24264 by Carstuff
Replied by Carstuff on topic 2001 cl600 crank no start
Sounds like an open on the harness 6 to 12 injectors. It's a bulk head joint. Check for open on the harnesa
Last edit: 8 years 1 week ago by Carstuff.
Time to create page: 0.267 seconds
