Potentiometer fixed resistor
  • autojoe
8 years 5 days ago #24290 by autojoe
Potentiometer fixed resistor was created by autojoe
Paul describes two types of potentiometers. Both have voltage sensing circuits inside the pcm. What does the one with the fixed resistor between the 5 volt ref and the signal wire for? Diagnostics? Doesn't the voltage sensing circuit used for diagnostics?
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 3 days ago #24339 by chief eaglebear
Replied by chief eaglebear on topic Potentiometer fixed resistor
for sensor circuit integrity testing if there is a short to ground you will protect computer from possible overload I think that's what you were asking ?
  • autojoe
8 years 3 days ago #24352 by autojoe
Replied by autojoe on topic Potentiometer fixed resistor
Thanks for reply. Paul stated that the signal wire in a potentiometer is a sensing circuit only and no path for current flow high impedance without the 5 volt from the fixed resistor. Then without 5 volt circuit is protected.
  • chief eaglebear
8 years 3 days ago #24353 by chief eaglebear
no prob bro don't be a parts changer
