‼️HELP‼️Engine computer Dodge Challenger
  • Warmbeergaming44
  • Warmbeergaming44's Avatar Topic Author
8 years 4 days ago #24324 by Warmbeergaming44
‼️HELP‼️Engine computer Dodge Challenger was created by Warmbeergaming44
So I recently had to replace my engine computer on my Dodge Challenger 2015 sxt(due to my push start not working). So everything was good the fine till the next morning. I get in the car and hit the push button....nothing i hit it about a good 5-8 times then it finally cranks. After that its good for the rest of the day. Please help me guys
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 3 days ago - 8 years 3 days ago #24338 by chief eaglebear
Replied by chief eaglebear on topic ‼️HELP‼️Engine computer Dodge Challenger
hi sir not a journeyman yet but I am curious as to exactly why you changed pcm out was there a driver out what signal was missing just want to know exactly why the computer was changed out its quite a process to rule out pcm scanner danner stresses going thru all powers and grounds and testing drivers too it must be conclusive as some pcms and modules are very expensive I am not familiar with push button starting circuits but some very specific testing should take place before rul;in g out modules
Last edit: 8 years 3 days ago by chief eaglebear.
  • Warmbeergaming44
8 years 3 days ago #24344 by Warmbeergaming44
Replied by Warmbeergaming44 on topic ‼️HELP‼️Engine computer Dodge Challenger
Well it was my mechanic that came to that conclusion. The engine would not turn over when i was pushing the start button.
8 years 3 days ago #24345 by juergen.scholl
Replied by juergen.scholl on topic ‼️HELP‼️Engine computer Dodge Challenger
So basically the no start problem was attributed to the pcm and now it looks like the same problem is back, that is what you are saying?
You should have a look at scan data to make sure the start request is seen by the car, the transponder is recognized etc. Data stream will be your friend on this one.
If you had any doubts about it then you should read on how the starting system operates. Next in line is wiring diagram and tests on the car.
  • chief eaglebear
8 years 3 days ago - 8 years 3 days ago #24354 by chief eaglebear
DONT BE A PARTS CHANGER !!!!!
8 years 2 days ago #24355 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic ‼️HELP‼️Engine computer Dodge Challenger
First fault finding step with the symptoms given is smack the starter a couple of times.
  • chief eaglebear
8 years 2 days ago #24356 by chief eaglebear
hi andy would those relays be comtrolled by computer that circuit is kinda COMPLEX FOR ME BUT I SEE EVERYTHING CONTROLLED BY COMPUTER ABOVE AND BEYOND THAT COULD ONE OF THE RELAYS NOT HAVE A GROUND THIS IS A VERY INTERSESTING CIRCUIT SORRY FOR THE LARGE CAPS
  • Warmbeergaming44
8 years 1 day ago #24394 by Warmbeergaming44
Yup, We replaced the engine computer and it was fine for a day or two. And back to the not working again. My mechanic is completely flummoxed and that is frustrating and worrisome to myself a non-mechanic but where there is a will there is a way. Will adhere to your post and come back with the findings on Monday. Thank you brother
