Sluggish movement and inability to climb hill
  • davidessiendcarguy
  • davidessiendcarguy's Avatar Topic Author
1 year 6 months ago #88698 by davidessiendcarguy
Sluggish movement and inability to climb hill was created by davidessiendcarguy
A client called me complaining about the car that has an acceleration problem. The car is 2007 dodge caliber SXT and the codes that were retrieved are U1146, P2770, P0963, P0967, P1729. The car moves very sluggish and can't climb slightest of bump on the road or a hill. Please, how can I fix this problem?
1 year 6 months ago - 1 year 6 months ago #88720 by Paul P.
Replied by Paul P. on topic Sluggish movement and inability to climb hill
Sounds like the CVT is in limp Mode.  ALL 3 codes are circuit high codes, maybe short to voltage, an open, or no ground reference.
The U code is most likely set because of the other three fault codes.  I've included the fault trouble trees, maybe there is something in common like 1 bad ground setting all 3 circuit codes off.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Never stop Learning.
Last edit: 1 year 6 months ago by Paul P..
1 year 6 months ago #88722 by davidessiendcarguy
Replied by davidessiendcarguy on topic Sluggish movement and inability to climb hill
Thank you so much sir. I've gone testing it and observed that there's no power in pin 3 of the solenoid
circuit using a test light and a DVOM. Alldata said there must be bright illumination like that of a battery. But there's no voltage when tester is in ground. What should I do next? Where's the power coming from, is it at the TIPM or PCM?
