1999 Mercedes Benz SLK 230 No power above 3K RPM P0170
  • 93Rubie
  • 93Rubie's Avatar Topic Author
7 years 11 months ago #24467 by 93Rubie
Car has ABS fault (broken wires), hardtop inop, and a radio causing a 3A draw (temp. fixed). The other concern is the car runs smooth until about 3K or below about 1/2 throttle. After that is falls on it face and does not make power.
P0170 is stored. I've cleaned the MAF. It reads about 2.7g/sec on my OTC Nemisys in OBDII mode.
Fuel trims are LT 30+%, ST is around zero at cruising speeds. 02's respond within reason. Above 3K or half throttle the 02's go stupid lean and the car falls on its face. I saw the MAF around 56 or so when this happens.
Tested the fuel pump all OK electrically, 5.5A. Fuel pressure under load is 58psi. Only drops when you let off the throttle to around 46 psi.
I hear no or see no evidence of vacuum leaks which should make it run like crap at lower RPM's not higher anyway.
All injectors OHM at around 15.7. I need to bring home my UScope to run them tomorrow. I also want to do a injector/fuel pressure test to make sure they are flowing fuel.
I'll admit this Eurotrash is different but similar to US/Asian vehicles but different enough to be a PITA.
I suspect this is a pure fuel delivery issue and if the injectors check OK, I'm going back to the MAF. Any ideas or more info on the MAF, I have no access to any good data on it.
Also with the MAF, unplugged its worse. With the MAP unplugged its about the same.
7 years 11 months ago - 7 years 11 months ago #24471 by Desmond6004
Normally small engines idle at 3g/s. I'd expect this vehicle to idle around 4.5 g/s or more based on my experience. I just googled the code www.obd-codes.com/p0170 . This is a case where a smoke tester in the intake system can really help. I'd think that either the MAF sensor is reading wrong or there is an air leak.
Last edit: 7 years 11 months ago by Desmond6004.
7 years 11 months ago #24479 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 1999 Mercedes Benz SLK 230 No power above 3K RPM P0170
MAF unplug test usually won't work on Mercedes, also Cleaning Bosch bead type analogue sensor will rarely show any improvement an it is not known to find either fake Chinese sensors or a an unsuitable Pierburgh sensor fitted in the original sensor unit.
  • 93Rubie
7 years 11 months ago #24500 by 93Rubie
Injectors are fine.
Tested MAP senor and MAF again. All OK electrically. The MAF throws an odd scope pattern with revs. It not very linear at all.
Scan tool says 2.7g/sec on a hot idle. If that is too low then that is my issue.
In my experience displacement should about equal MAF g/sec readings at idle. This I have found to be true on most US/Asian vehicles.
I hunted for any kind of leaks with propane and found none. I do not have a smoke machine at home and I doubt I'll be borrowing one from work.
Give what you have written it sounds like I have a MAF issue. I've ruled out fuel delivery as the pressure, pump amperage, and injectors are all OK. I flow tested the injectors as well. All dropped 10psi.
7 years 11 months ago #24505 by Desmond6004
I recently did a blog about smoke effects for photography but I think an insect smoker would be very useful for leak detection. Just use pure baby oil and you're away.
7 years 11 months ago #24551 by Andreastech
Hmmm ...
Have you take a look at the exhaust or the catalyc converter ? just to be one the "safe side" :)
Also, to check MAF 100%, check voltage with the scope from idle to WOT
... there should be no drop out etc ...
OFC there is a case i am wrong in my thinking at all
  • 93Rubie
7 years 11 months ago #24612 by 93Rubie
I did do a back pressure check just to cover my six. Its fine.
  • 93Rubie
7 years 11 months ago #24703 by 93Rubie
Update. New MAF installed drove car. Runs great. I left my scan tool at work so I'll need to grab that to clear the CEL and run OBDII monitors but so far it looks good. I'd like to note the good MAF readings and I'll update those here.
  • 93Rubie
7 years 11 months ago #24726 by 93Rubie
Hot idle no load 2.8g/sec. Car running well.
