04 sierra 1500 4.8l 4x4 evap vent circuit
- Matts Auto
- Thank you received: 28
- chavez96
To run the monitors on some vehicles you need to do special driving conditions at different drive cycles to set evaporate and cat monitors. But if it’s due for a smog evap can be incomplete but not cat monitor. I check all data to see if I can find the driving conditions for this truck??
- Matts Auto
No codes set during your testing with the vent solenoid unplugged? That should have at least set a circuit low code, IF everything was working correctly. :silly: How were you testing the wiring at the vent solenoid? Test light, DMM, Power Probe?
Has anyone tried disconnecting the battery and touching the cables together? Just in case the PCM is logic locked into activating that driver.
- Matts Auto
- The Auto Tech
- Thank you received: 8
Matts Auto wrote: I did try disconnecting the battery and holding terminals together. Vent was stuck in on position with koeo driver stuck on & still unable to control circuit with scan tool. I tested first unplugging solenoid with dmm & had solid power & ground. Then with incadescent test light then cut control wire by pcm connector & tested control wire coming out of pcm same.
Way ahead of me!
Maybe check the current draw of the vent solenoid? Just to make sure it's not part of the problem. I'd expect less than 1A.
