ECU programing error message
  • Failed Test
  • Failed Test's Avatar Topic Author
1 year 5 months ago #90908 by Failed Test
ECU programing error message was created by Failed Test
2004 E350, trying to reprogram the ecu with FJDS and Autel vci , it recognizes everything goes through all the motions but when it's at the turn keyoff, then on I get
Error code:  9 - 0x0       851082             anyone know exactly what this means?
1 year 5 months ago #90911 by Chad
Replied by Chad on topic ECU programing error message
I don't know what that specific code means but, make sure you have a good, stable power supply and check to ensure that you have the autel VCI drivers installed on your laptop.
1 year 5 months ago #90916 by Noah
Replied by Noah on topic ECU programing error message
I also don't know what the code means, but have encountered "programming failed" messages after successfully programming modules.
1 year 5 months ago #90918 by Tyler
Replied by Tyler on topic ECU programing error message
The 851082 fault comes up in a bunch of different threads over on Diag.net if you're a member:
diag.net/search?q=851082
  • Failed Test
1 year 5 months ago #91299 by Failed Test
Replied by Failed Test on topic ECU programing error message
Thanks for your response, so I need to see 18v on pin 13 while trying to program is what I'm understanding here? FEPS circuit.
1 year 5 months ago - 1 year 5 months ago #91668 by Chad
18v on pin 13 enables the module to be programmed.
A few years ago there was a problem with fjds version 113, I believe. I ended up in a situation similar to yours, even though I had 18v on pin 13. I don't recall the error code but, the solution for me was to manually install "as built data".
Last edit: 1 year 5 months ago by Chad.
  • Failed Test
1 year 5 months ago #91689 by Failed Test
I'm going to assume this 18v comes from the vcm? If there isn't 18v would it be possible to artificially supply the wire with 18v? Or would it fry the vmc if its not built for that? Could I De-pin #13 from the dlc and add 18v without the vcm?
Thanks
1 year 5 months ago - 1 year 5 months ago #91780 by Chad
The 18v is supplied by the programming tool.
If your tool is not supplying the 18v, I suppose that you could supply an external source but, if the j2534 box is not working, properly, I don't think that I would trust it do the programming.
If you give it a try, be sure to let us know how it went.
Good luck!
