2003 Corolla p0302
  • SakeenahMD
  • SakeenahMD's Avatar Topic Author
7 years 10 months ago #25596 by SakeenahMD
2003 Corolla p0302 was created by SakeenahMD
Hello
Looking for flow charts on checking computer driver for cylinder 2 ignition coil. I have a p0302. Brand new coil and spark plug. Still same misfire. Looking into computer driver before checking for burnt valves
7 years 10 months ago - 7 years 10 months ago #25603 by Tyler
Replied by Tyler on topic 2003 Corolla p0302
Before you go digging into the coil driver, have you confirmed that the misfire is on the #2 cylinder? Does the misfire happen at all times, or under load? Engine cold, hot?
Probably the easiest way to confirm wiring integrity to the coil, including the computer driver, is to check for spark out of the coil boot. Remove the coil from the plug tube but leave it connected. Have an incandescent test light connected to a ground, and keep the tip inside the coil boot while someone else starts the engine. Here's a video demonstrating the idea:
Verify that there is spark, and how far you can make it jump out of the boot by pulling the test light away. If good spark is being produced, it'll produce a sharp 'crack' and a blue color. While you're there, drag the tip of the test light up and down the coil itself to check for high voltage leakage. I know the coil is new - do it anyway. ;) Compare to another coil if you have doubts.
If strong spark exists, there is no wiring or driver issue. Your misfire lies elsewhere. If it does not exist, then we can go into checking power/ground/control at the coil. I dunno that I've ever seen a failed coil driver on a Toyota before. :silly: A restricted injector or a leaking intake gasket would be far more likely on this engine.
Last edit: 7 years 10 months ago by Tyler.
The following user(s) said Thank You: Andy.MacFadyen, aboudi.naddaf
7 years 10 months ago #25630 by juergen.scholl
Replied by juergen.scholl on topic 2003 Corolla p0302
Do as advised by Tyler. A P0302 doesn't necessarily mean you got an ignition misfire.
Per OBD definition the computer is allowed to look of either of the two, ignition and injection. If there was no fault with the injector circuit (which is to set a P0202 for the #2 cylinder in a given case) the pcm would flag a P0302, although very well a clogged injector can be the cause of the misfire.
Desccribe the conditions when the misfire occurs.
The following user(s) said Thank You: Tyler, aboudi.naddaf
7 years 10 months ago - 7 years 10 months ago #25635 by Desmond6004
Replied by Desmond6004 on topic 2003 Corolla p0302
Regarding testing the coil driver - basically an oscilloscope pattern should show if it is switching correctly, I think it's normally a 5v trigger and it should have a slope to it - also check for good earth and positive feed - make sure there isn't too much voltage drop when it switches.
Last edit: 7 years 10 months ago by Desmond6004.
  • SakeenahMD
7 years 10 months ago #25725 by SakeenahMD
Replied by SakeenahMD on topic 2003 Corolla p0302
I swapped injectors already and performed a cylinder drop test by unplugging the injectors and I know that's not the problem. At this point I'm looking at either timing or computer. There's a tapping noise that's present around cylinder 2. Cylinder is contributing but not even 50% according to my testing.
  • SakeenahMD
7 years 10 months ago #25726 by SakeenahMD
Yeah I don't own a scope
  • GeekDIYMechanic
  • GeekDIYMechanic's Avatar
7 years 10 months ago #25727 by GeekDIYMechanic
Replied by GeekDIYMechanic on topic 2003 Corolla p0302
Are you able to perform a clear flood crank? If so, does the cranking sound even? If not, that would mean you're having a compression problem.
7 years 10 months ago #25756 by Rev Scott
Replied by Rev Scott on topic 2003 Corolla p0302
It sounds like you have a mechanical failure, not a bad coil driver.
It may be time to pull the valve cover and have a look at your valve lash clearances. That tapping could be a good indicator of the issue.
7 years 10 months ago #25758 by Rev Scott
But, if you want to quickly check injector pulse so you can cross it off your list, you could make a homemade noid light using a 194 style automotive bulb. Steal it from your tag light, then put it back when you are done.
Just unwind the leads away from the glass base, and plug it into the disconnected two-pin injector connector.
You can watch the flash and see if it is being fired, you can even compare one to another and make sure its flashing for the same length of time.
The following user(s) said Thank You: Tyler, SakeenahMD, aboudi.naddaf
7 years 10 months ago #25808 by Noah
Replied by Noah on topic 2003 Corolla p0302
Rev Scott wrote: But, if you want to quickly check injector pulse so you can cross it off your list, you could make a homemade noid light using a 194 style automotive bulb. Steal it from your tag light, then put it back when you are done.
Lol, I've employed that tactic :)
7 years 10 months ago #25809 by Tyler
Now that's some resourceful thinking right there. B)
  • SakeenahMD
7 years 10 months ago #25945 by SakeenahMD
Thanks everyone for your input. I'm pretty sure it's mechanical and customer will have to decide whether to fix an old beater or live with it
