2007 Mercedes C280 Stalling No MIL
- darnold
7 years 10 months ago - 7 years 10 months ago #25699
by darnold
2007 Mercedes C280 Stalling No MIL was created by darnold
Hi we have a 2007 Mercedes C280 it's has a intermittent problem with stalling so far only at stop lights. There's no codes set in the PCM and the MIL light has never come on. In fact the Mercedes dealers factory trained service technicians could not find any source of the problem with all of their high end factory scan tools and documentation.
I'm trying to figure out how to diagnose this problem. It has a key fob which has an infrared transmitter for security. The battery in the key fob was recently replaced but for some reason the unlock button has not been working properly. Could the key fob be the cause?
The fuel pump recently failed and was replaced by the dealer. Perhaps they miss something in the fuel pump replacement. It was $700 parts and labor for the new Mercedes Factory fuel pump. It did not solve the stalling issue. Previously it would stumble while in a turn. The car is never run to empty. The fuel tank is always kept topped off regularly.
I love the scanner danner videos and I am a subscriber to your Channel great videos I consider you one of the best experts in diagnosing these types of issues. I hope that you may have worked on similar issues and have some pointers to get us going in the right direction. Looking forward to hearing from you.
Thank you
Thank you
Last edit: 7 years 10 months ago by darnold. Reason: Add Icon
- Desmond6004
7 years 10 months ago #25701
by Desmond6004
Replied by Desmond6004 on topic 2007 Mercedes C280 Stalling No MIL
It sounds to me like it would be worth checking fuel pressure when it happens. Going around corners and stopping at lights bring to mind movement of the fuel in the tank. Otherwise possibly related to lifting your foot off the accelerator pedal - maybe it's not seeing idle position?
7 years 10 months ago #25705
Replied by Andy.MacFadyen on topic 2007 Mercedes C280 Stalling No MIL
I would be first investigate if this is an idle speed control issue or just dirty throttle body . At idle speed the engine computer has to compensate for added loads on the engine from ancillaries such as electrical loads on the alternator, air conditioning and power steering. Stalling when turning street corners at close to idle rpm can often be due to the increased loads from the power steering.
So a good plan of attack without a bi-directional scan tool would be first to check the connectors for the power steering pressure sensor and ac pressure sensor are fully plugged in and making a good connection and then clean the throttle body.
