96 Jeep Grand Cherokee 5.2 timing chain bad?
  • kris.sondors
  • kris.sondors's Avatar Topic Author
7 years 10 months ago - 7 years 10 months ago #25902 by kris.sondors
96 Jeep Grand Cherokee 5.2 timing chain bad? was created by kris.sondors
96 Grand Cherokee with a 5.2 customer complains that the vehicle will randomly stall. After doing a test drive I noticed it did it when the engine would go to an idle so when coming to a stop or reversing out if a parking lot it would sometimes stall. Fuel and ignition system checked out, same with compression test. The engine had 280k miles on the original engine. Anyways, hooked up my scanner and compared the cam and crank counts together on the graph and I noticed that they don't align or stay synced. Is this because of the timing chain being loose or could it be something electrical like pcm, sensors, or wiring? Thanks for looking over this!
Video of the issue
streamable.com/yelwe
Last edit: 7 years 10 months ago by kris.sondors.
7 years 10 months ago #25904 by Paul6004
Replied by Paul6004 on topic 96 Jeep Grand Cherokee 5.2 timing chain bad?
It could be as simple as an idle control valve - if this vehicle has one that is.
  • kris.sondors
7 years 10 months ago #25907 by kris.sondors
Replied by kris.sondors on topic 96 Jeep Grand Cherokee 5.2 timing chain bad?
Paul6004 wrote: It could be as simple as an idle control valve - if this vehicle has one that is.
It's does have one, however the IAC step count matches the requested IAC steps. If forgot to mention, the jeep runs on the rougher side and shakes at certain rpms
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 10 months ago #25918 by cheryl hartkorn
Replied by cheryl hartkorn on topic 96 Jeep Grand Cherokee 5.2 timing chain bad?
sounds like you have a dropping out crank or cam sensor. you have a scope?
  • kris.sondors
7 years 10 months ago #25923 by kris.sondors
cheryl hartkorn wrote: sounds like you have a dropping out crank or cam sensor. you have a scope?
Unfortunately no....
