2004 VW jetta 1.8t transmisson
- Chasek
7 years 9 months ago #25987
by Chasek
2004 VW jetta 1.8t transmisson was created by Chasek
I have a 2004 VW Jetta and the car stopped going into reverse I did some online research and most of what I found said it was the tcm. I set the tcm to be repair and now that the tcm is installed I get a U0101 fault. I did find most of the grounds and checked and cleaned them. I can start the car just fine but there is no selector display on the dash. Also when putting it in and gear it trys to go forward what's my next step
- chief eaglebear
- Thank you received: 70
7 years 9 months ago #26078
by chief eaglebear
Replied by chief eaglebear on topic 2004 VW jetta 1.8t transmisson
curious what part of tcm was broke and how did they fix it
- Desmond6004
7 years 9 months ago - 7 years 9 months ago #26103
by Desmond6004
Replied by Desmond6004 on topic 2004 VW jetta 1.8t transmisson
I'd check the fuses as well - to make sure your TCM has power. The next step is to get a pinout of the module and start checking wires. The CAN communication wires are twisted together - hopefully someone can provide the relevant information so you can check them for communication signals.
Last edit: 7 years 9 months ago by Desmond6004.
- chief eaglebear
7 years 9 months ago - 7 years 9 months ago #26133
by chief eaglebear
Hi did you have a driver go out when tcm was replAced I was curious how it was ruled out
Last edit: 7 years 9 months ago by chief eaglebear.
- chief eaglebear
7 years 9 months ago #26134
by chief eaglebear
Were all inputs and outputs verified and proper power and ground I was wondering why tcm was replaced and if there were any inputs from tcm that were not working was ecm communicating with tcm
- Chasek
7 years 9 months ago #26559
by Chasek
Replied by Chasek on topic 2004 VW jetta 1.8t transmisson
The tcm board had corroded pins and cracked solder how ever that didn't solve the problem the car still only trys to go forward in all gears
- kostelectronics
7 years 9 months ago - 7 years 9 months ago #26632
by kostelectronics
Replied by kostelectronics on topic 2004 VW jetta 1.8t transmisson
I know These cars "good", but only the european Versions. If you have all Power + GND's, CAN signals (scoped ok), you have 99% a faulty TCM. Have you got a refubished unit or your original repaired?
I can provide you the wiring diagrams if you want, but it's nearly clear for me that your TCM is faulty..
Last edit: 7 years 9 months ago by kostelectronics.
