Ford expedition 2003 5.4L no crank no start B1602 code
  • Malqubaiti
  • Malqubaiti's Avatar Topic Author
1 year 4 months ago #91890 by Malqubaiti
Hi Team,
I was working on this ford doing tune up job and i did replaced coils and injector plugs as they were broken. when i started the car injector for cylinder one wires was not sealed to the connector and the mistake i did i pulled it out of the connect and touched the fuel rail while the car was running. suddenly car shutoff and wont crank again. I scanned the car and code B1602 showed up. its related to the key or the immoblizer.
any idea where should start?
1 year 4 months ago #91892 by Noah
If you touched the positive feed to the fuel rail with the engine running, it would probably blow a fuse. I would start by checking fuses.
  • Malqubaiti
1 year 4 months ago #91893 by Malqubaiti
I already checked fuses. for PCM there is two fuses and a relay. all okay.
1 year 4 months ago #91906 by Noah
Which wire touched the fuel rail? Was it an immediate stall as soon as it happened?
Even with an immobilizer code, the immobilizer will not kill a running vehicle, and I don't think it will stop a car this old from cranking. You say this a a no crank/ no start, correct?
