2016 Subaru Outback 2.5i Premium 5 v reference irregularity P0122 and P0222
  • brianmstoltzfus
  • brianmstoltzfus's Avatar Topic Author
1 year 4 months ago #91938 by brianmstoltzfus
I am posting a scope capture of battery voltage, 5 v reference to the throttle body, and throttle body position sensor 1 data. The irregularity in the 5 v reference threw me way off until I compared it with a known good car and found it looks identical. The irregularity changes with engine rpm, it is happening twice per revolution. Does anyone know the reason for this? 1 picture is scope set to 1 ms per frame and the other picture is zoomed out. I am diagnosing codes P0122 and P0222 in this car. The codes set once and caused the car to go into fail-safe but I have not been able to duplicate.
  • Away
1 year 3 months ago #91970 by Chad
I suspect that what you are seeing is just noise from coil/ignition events. The more you use a scope, the more you will see this. The more you see it, the easier it will be to ignore it.
  • brianmstoltzfus
1 year 3 months ago #91985 by brianmstoltzfus
Thankyou for this help!
