1998 vortex 350
- markg123
7 years 9 months ago #26191
by markg123
1998 vortex 350 was created by markg123
1998 votex 350 no start test fuel pressure 60psi will start with starting fluid in intake will not stay running on its own has code 1351 tested white and black wire from ignition control module has pulse tested pink power wire for injector test light on bright test blue and white wire for control ground and it has pulse try to check security passlock had no light pulled dash installed known go light still no security light on need to know how to test passlock system with no light on any help would be appreciated
- johnathon.balderas
- Stay humble and thank God everyday for waking up.
- Thank you received: 19
7 years 9 months ago #26196
by johnathon.balderas
Replied by johnathon.balderas on topic 1998 vortex 350
The security light come on at all?
- markg123
7 years 9 months ago #26203
by markg123
Replied by markg123 on topic 1998 vortex 350
no security light at all today i pored gas in intake and keep poring to keep motor running for 3 or 4 minutes then truck ran on it own after doing this 3 time now truck will start on it own and has miss fire code for number 2 only has 55 psi fuel presser at idle not sure if injectors bad or fuel pump
7 years 9 months ago #26204
55 is fine at idle as long as it stays above 50. Not sure what happened or why it is starting now.
- Desmond6004
7 years 9 months ago #26207
by Desmond6004
Replied by Desmond6004 on topic 1998 vortex 350
What is the history of the problem? Did it just suddenly stop going or has it been "off duty" for a while?
- markg123
7 years 9 months ago #26225
by markg123
truck was running then parked for year then would not start no running and sometimes gets code 1351 high ignition control volts
- Desmond6004
7 years 9 months ago #26226
by Desmond6004
Possibly totally unrelated but the other day we had a Ford in here that had a flat battery for a few days then wouldn't start. - We had to re-link the PCM and immobiliser modules because they had 'lost touch' with each other.
