1998 ford E350 5.4 V8
  • Jorgecardenas26
  • Jorgecardenas26's Avatar Topic Author
1 year 5 days ago #92354 by Jorgecardenas26
1998 ford E350 5.4 V8 was created by Jorgecardenas26
Good afternoon.  I could use some help. I have a 1998 ford E350 5.4 v8 vehicle shutters when going around 30-35 mph in 4th gear with little throttle.  If you let go of throttle it goes away. If you give it more throttle it goes away. Only code i have is p0420 stored.  I removed the driveshaft and it seams fine.  Carrier bearing is good.  Tires are good. Any suggestions i would appreciate it.  And if possible you can call me anytime 9092896994. Name is Jorge.
1 year 4 days ago - 10 months 4 weeks ago #92356 by Noah
Replied by Noah on topic 1998 ford E350 5.4 V8
Sounds like possible torque converter shudder. You can monitor the data pid for converter lock up and see if the symptom aligns with converter clutch engagement. Usually tapping the brake pedal cancels converter operation, so if you can hold it in the sweet spot where the shutter is happening and tap the brake with your left foot and see if the shutter goes away. I have had very good luck with fluids friction modifiers like Shudder Fix to correct this issue, even if just temporarily
Last edit: 10 months 4 weeks ago by Noah. Reason: Shitter, ha!
  • Jorgecardenas26
10 months 4 weeks ago #92445 by Jorgecardenas26
Replied by Jorgecardenas26 on topic 1998 ford E350 5.4 V8
It seems like i do have a torque converter shutter. I replicated the system and tap on the break and it does go away. What would be the best fixed for this?
10 months 4 weeks ago - 10 months 4 weeks ago #92449 by Noah
Results are usually instant with the Lube Guard shudder fix addative. I would go ahead and add a bottle to the trans fluid and if you find it necessary, consult a transmission rebuild specialist.
  • Jorgecardenas26
10 months 4 weeks ago #92450 by Jorgecardenas26
I did add a bottle of line guard shutter fix and it did not help.
10 months 4 weeks ago #92451 by Noah
Oh well, that's disappointing.
Transmission internal is not something I am familiar with. Like I said, I would consult a transmission rebuilder.
Let us know how you make out
