Need help 2007 Porsche Cayman S 3.4L
  • LegendsAuto
  • LegendsAuto's Avatar Topic Author
11 months 2 weeks ago - 11 months 2 weeks ago #92409 by LegendsAuto
Need help 2007 Porsche Cayman S 3.4L was created by LegendsAuto
Hello people,
I am getting DTC P0706 Multi switch. The gear indicator on the instrument cluster is flashing that its in 4th gear. Also has "Tiptronic emergency run" warning flashing. All I have is a wiring diagram but unsure what diag procedure I should perform without information regarding the DTC flow chart being available. It does start and goes into gear
Last edit: 11 months 2 weeks ago by LegendsAuto.
11 months 1 week ago #92420 by memunamua4
Replied by memunamua4 on topic Need help 2007 Porsche Cayman S 3.4L
Hi friend This is Abdul Salam from Ghana, with regard to your question, you can start by checking the wiring of theĀ Transmission Range Sensor or Park/Neutral safety switch, if the intergrity of the wiring is good then replace the Sensor.
Time to create page: 0.251 seconds
